Re: Is the H govenor spring ajustable?
Posted by rustyfarmall on March 06, 2004 at 07:31:55 from (207.32.13.252):
In Reply to: Is the H govenor spring ajustable? posted by Nick on March 05, 2004 at 16:15:16:
I have a 1940 H with that same type of spring, I was able to adjust mine to tighten it up and get the RPMs it was supposed to have. Also, the hole that the hooked end of the spring goes into gets worn out, it can be welded or brazed shut, and a new 1/4 inch hole drilled. It improved the governor quite a bit.
Post A Followup
: Re: Re: Is the H govenor spring ajustable?
