Re: h front end shimmy
Posted by Farmall Ed on March 09, 2004 at 15:30:38 from (205.185.70.12):
In Reply to: h front end shimmy posted by farmer on March 09, 2004 at 13:43:01:
Farmer I had the same problem with a regular H,I think the super H may be the same. The cap nut on the front of the oil reservoir was loose,this nut holds the steering shaft in and the bearing that goes on the front against the worm gear was in pieces. I put in a new bearing,and turned the round gear 180 degrees into an area that wasnt worn where it mates with the worm gear. Most Hs have cut gear here, so turning it is out. After putting it back together it was almost perfect,then when I put new tires on it drives like a new one.Sorry for the long answer but I hope this will give you some ideas.Ed
Post A Followup
: Re: Re: h front end shimmy
