Re: Super C Clutch Replacement
Posted by gauger on March 10, 2004 at 06:05:17 from (12.155.240.196):
In Reply to: Super C Clutch Replacement posted by Brian Schmidt on March 09, 2004 at 18:48:59:
Brian, the older style has a graphite ring that is not serviceable separately. You have to replace the whole thing. The newer bearing type has a different cast iron carrier. When I restored a Super A recently I wanted to go with the bearing type so I went to a tractor boneyard and bought the carrier. The functional difference is that the bearing turns with the clutch, the graphite ring is stationary and the clutch fingers slide on it as the clutch rotates. Either will outlast you and me.
Post A Followup
: Re: Re: Super C Clutch Replacement
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
