Re: Re: Re: Re: Re: Valve tappet adjustment
Posted by riverbend on March 10, 2004 at 07:13:30 from (208.160.33.180):
In Reply to: Re: Re: Re: Re: Valve tappet adjustment posted by CNKS on March 09, 2004 at 20:11:54:
It sounds like your cam is ground off center. The base circle of the cam should, in theory be a circle i.e. a constant radius. In a higher speed motor, you could have some valve overlap, and would want to adjust the intake when the exhaust is completely open and vice versa. With these motors, I doubt the quieting ramps are much of an issue either.
As long as the valves remain closed it should be all right. Besides staying shut, the valves all should open the same amount. Interesting stuff. I'm going to check mine next time I adjust the valves .
Post A Followup
: Re: Re: Re: Re: Re: Re: Valve tappet adjustment
