Re: priming parts
Posted by CNKS on March 10, 2004 at 08:14:17 from (207.178.99.131):
In Reply to: priming parts posted by Tom South jersey on March 10, 2004 at 04:58:49:
To clarify slightly -- If you are priming small parts, and leaving them for days, weeks or months, and you cannot keep them in an absolutely dry place, the only primer that will prevent rust is an epoxy primer, usually applied with a spray gun. I don't know if there are epoxy primers in spray cans or not. If you use spray can primer, or any primer from a gun that is not epoxy, you may have problems (emphasis on the may, see Rustyfarmall's post), as such primers are not waterproof. Spray gun epoxy primer can be applied and left alone. However, before topcoating, it must be scuffed and applied again. I don't do it that way, but apply a rust preventative on clean metal (Picklex 20), then use epoxy within a couple of days of topcoating. Again all of this is on the paint and bodywork forum. I believe most epoxy primers are compatible with most anything, but, as Dave_ID said, you should use the same brand of paint throughout, that way there will be no surprises. I only use spray cans (reluctantly) for touch up work, or on some small part that I messed up and don't want to load my spray gun.
Post A Followup
: Re: Re: priming parts
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
