Re: Valve tappet adjustment
Posted by Andy Martin on March 10, 2004 at 17:35:42 from (67.248.199.137):
In Reply to: Valve tappet adjustment posted by CNKS on March 09, 2004 at 14:44:44:
Interesting. I've never bothered to check a cam in the "closed" position. I used to always set them at idle but am too old to ignore the flying oil anymore. The easy way on all engines is like was said, is to set a valve when it's mate is fully open. I never can find chalk so I just go around a couple of times to recheck myself, and I always set them a little loose. I do have several tractors with rocker arms which have holes worn in them (the reason for this post) by the valve stems. The only way I have found to set them is by the "turn of the screw". Screw the adjuster in until the rocker tightens up, then back off enough turns (about 1/4 turn on an M) until you get enough clearance to not burn a valve. These worn rockers should be replaced, but if anyone tries to adjust one with a feeler gauge he will be off by the amount of the depression worn into the rocker. I have a '39 M with probably 0.100" depression worn in every rocker but runs smooth as glass when the valves are set right, even with the bad rockers.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
