Re: Re: Re: Re: Re: Re: Valve tappet adjustment
Posted by CNKS on March 10, 2004 at 18:00:30 from (207.178.99.60):
In Reply to: Re: Re: Re: Re: Re: Valve tappet adjustment posted by GG on March 10, 2004 at 14:35:59:
Thanks for the information. Firing order is 1342. Meaning I can use the crankshaft mark for 1 and 4. 3 is 1/2 rev from 1, and 2 is 1/2 rev from 4. Yes, I could figure which valves are closed with any cylinder on TDC, but having checked a rechecked them all, I believe all are +/- .001 from 0.017. Don't want to adjust with the engine running, because I prefer to work slow, by the time I got done there would be oil all over me and everything else. I have heard of using a valve cover with the top cut out, to prevent getting oil all over.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Valve tappet adjustment
