Re: Pre- lube Startup
Posted by Steve from MO on March 10, 2004 at 19:01:03 from (168.166.54.11):
In Reply to: Pre- lube Startup posted by Mike on March 10, 2004 at 18:29:06:
Wait for some of the other guys. I know on cars you could spin the oil pump with an attachment on an electric drill. It went in through the hole where the distributor fastens.
Post A Followup
: Re: Re: Pre- lube Startup
