Re: I bit the big one and got a Saginaw 3 pt
Posted by Road Warrior on March 10, 2004 at 21:29:34 from (216.174.170.59):
In Reply to: I bit the big one and got a Saginaw 3 pt posted by Jonesy on March 10, 2004 at 18:25:40:
third party image
Here's a pic of my valve and mounting method. I used a piece of 2 x 4 steel, I think it's about 30" long. Drilled holes to bolt onto the factory drawbar brackets(on front side of axle housing), and had to cut a couple notches for the "ears" to fit in the 2 x 4 tubing. I welded a couple of 1/2" bolts to the top, which hold the 3" angle iron the valve is mounted on.
CNKS is right on with the plumbing directions, only I ran my return line into the bottom of the belly pump housing. Remove the drain plug and use a 1/2" street L. That way it won't burp and shoot oil out the fill tube up top.
Post A Followup
: Re: Re: I bit the big one and got a Saginaw 3 pt
