Re: Pre- lube Startup
Posted by Randy in NE on March 11, 2004 at 04:05:34 from (216.58.237.20):
In Reply to: Pre- lube Startup posted by Mike on March 10, 2004 at 18:29:06:
If you have pre-lubed the bearings and all of the other moving parts then you are ok. Any time you shut off your engine and let it sit then all that you have at startup is a light film of oil that has not dripped back down into the pan. There really isn't much difference between an overhaul with pre-lube and starting an engine that has sat there for months without running. That is why the pre-lubing of the parts is important. You do want to check for oil pressure right away and verify that you are getting oil to the top of the engine.
Post A Followup
: Re: Re: Pre- lube Startup
