Re: Pre- lube Startup
Posted by Stan(VA). on March 11, 2004 at 04:19:28 from (208.59.156.171):
In Reply to: Pre- lube Startup posted by Mike on March 10, 2004 at 18:29:06:
The suggestions you've received all sound good, one more thing that I've used occaisionally is to leave the oil filter loose till the last thing (the very last thing before you hit the starter) and pour the last quart of oil straight down the oil filter openings. If everything is ready to start right up then it won't have time to all drain back yet and that is the quickest I have seen oil pressure jump up.
Stan(VA).
Post A Followup
: Re: Re: Pre- lube Startup
