Re: Re: Re: 656 T/A use
Posted by Jimmy King on March 11, 2004 at 10:00:42 from (207.69.137.22):
In Reply to: Re: Re: 656 T/A use posted by TJ on March 11, 2004 at 09:06:16:
Forward is direct drive, back is TA, when it is in TA with no load going down hill it will freewheel letting the tractor run away. [Georgia over drive] Normally use the high side, as long as you are under load so it won't freewheel you can use the low side. exampel you are plowing on high side tractor starts to pull down pull the TA lever back it is just like shifting to a lower gear. No you do not use the clutch.
Post A Followup
: Re: Re: Re: Re: 656 T/A use
