Re: Pre- lube Startup
Posted by Dan Kelley on March 11, 2004 at 10:14:30 from (140.32.120.18):
In Reply to: Pre- lube Startup posted by Mike on March 10, 2004 at 18:29:06:
Take an old pump-up garden sprayer. Fill the can of the sprayer with a quart or two of engine oil. Modify the hose to attach to the oil pressure guage fitting on the engine. Pump all the oil into the engine, but stop before you start blowing air into the oil system. You should be good to go.
Post A Followup
: Re: Re: Pre- lube Startup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
