Farmall Tractors Discussion Board
Re: Re: Re: brakes on super mta
Posted by john d on October 19, 1999 at 07:47:32 from (206.141.74.34):
In Reply to: Re: Re: brakes on super mta posted by wayne on October 19, 1999 at 03:09:28:
Excellent advice so far! When you're done with the insides, check the rubber boot that's on the lower part of the brake housing to see if it will still keep moisture out. Water is DEATH to these brakes. A quick coat of paint over the upper surface of the housing will help keep moisture out of the system after re-assembly.
Post a Followup
: Re: Re: Re: Re: brakes on super mta
