Re: Re: Re: I bit the big one and got a Saginaw 3
Posted by Andy Martin on March 11, 2004 at 18:57:13 from (67.249.16.67):
In Reply to: Re: Re: I bit the big one and got a Saginaw 3 pt posted by CNKS on March 10, 2004 at 20:35:15:
With a belly pump you have to pull the rod back to the detent (some won't hold) to get continuous pressure out of any of the ports.
Only with a SM magneto pump does the "Christmas tree" help you.
By the way, if the belly pump is working right, the rod will auto release when flow stops (cylinder bottoms out). I found this out by trial and error and it only works on a few of my tractors, but when mowing hay with an M and NH 479 Haybine you just pull it back hard to the detent and pay attention to making a sharp turn, the hydraulice will reset and you can let down and mow when you are ready.
Post A Followup
: Re: Re: Re: Re: I bit the big one and got a Saginaw 3
