Re: front main seal question
Posted by BIG JOHN on March 12, 2004 at 18:28:28 from (64.12.97.12):
In Reply to: front main seal question posted by bob s on March 11, 2004 at 17:53:00:
Bob: The front end has to come off in order to get the crankshaft pully off. First remove the raditor then the lower water inlet pipe has to come off and then the front end will come right off. Remove the fan and then you are ready to pull the pully. You will need a split bearing puller in order to pull the pully without breaking it.
GOOD LUCK
Post A Followup
: Re: Re: front main seal question
