Re: power steering help
Posted by Bob on March 15, 2004 at 09:54:25 from (66.163.134.177):
In Reply to: power steering help posted by Jerry Davis on March 15, 2004 at 07:27:52:
I have a 424 IH with the CharLynn torque generator power steering unit that is fed off of a flow divider from the main pump. I am planning to install a separate pump for the power steering, because the flow divider bleeds a steady flow of a couple of gallons a minute from the hydraulic system, reducing the flow available to the 3 point, or remote valves.
Before you decide go do the flow divider route, be aware that you will loose flow in the main system.
As far as adjustments, if you get the proper flow divider for power steering use, it is pre-set, and there are no adjustments to be made.
Post a Followup
: Re: Re: power steering help
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
