Re: HELP!!!! Supes C tune up
Posted by Wayne Swenson on March 15, 2004 at 17:27:27 from (66.228.233.162):
In Reply to: HELP!!!! Supes C tune up posted by R. Bishop on March 15, 2004 at 16:40:46:
I would suspect the points are about shot.
Is there a dropping resistor in the ignition primary circuit? (battery>switch>resistor>coil>points>ground>battery)
Is the coil primary grounded like the battery? (assuming 12 volt - ground, then the - terminal on the coil must be connected to the points)
A weak spark can cause your troubles to act like carburetion problems.
Take a look at the points; if they are pitted badly then be sure to get a resistor in line from switch to coil. Or buy a 12 volt coil with an internal resistor. AND replace the points!!
Post a Followup
: Re: Re: HELP!!!! Supes C tune up
