Re: Is there a way to adapt a hub from 34 to 38 ??
Posted by oleblu on March 15, 2004 at 17:33:15 from (216.166.192.250):
In Reply to: Is there a way to adapt a hub from 34 to 38 ??? posted by Matt on March 14, 2004 at 19:46:05:
Matt, if you look at most tractors set up with the 42" rubber you will find they use a 38" center hub and just weld flat steel "pads" with holes in them to the rim. I wouldn't think this would be too hard to acomplish if you have any mechanical skills at all. The only down side is if you aren't carefull to get everything centered, it may "lope" down the road. Also if you do this, you MUST dismount the tires before you start welding on the rims. Jim Thurnau
Post a Followup
: Re: Re: Is there a way to adapt a hub from 34 to 38 ??
