Re: 6 Cylinder M
Posted by ChadS on March 16, 2004 at 20:47:37 from (66.228.96.236):
In Reply to: 6 Cylinder M posted by jason on March 15, 2004 at 20:04:41:
It can be done. for frame rails, I would use 560, it is the same bell housing bolt pattern for the rails. The M frame rails will be too short to install a bolster, unless you lengthen them. then you can use the M rails, front end, and steering. Radiator will be tough, Lower hose on the M radiator is on the opposite side, so maybe use an H radiator. The flywheel off the 560 should work in the M, you may have to recut the flywheel to adapt the starter ring from the M to the 560. You would need to measure the distance from the engine back plate, to the back edge of the starter ring on the M, and the 560 to see what the spacing is. Clutch, 560, disk maybe Super M or the bigger M-450 disk to match the diameter of the flywheel and match the slines on the M input shaft. I know the 6 cyl will bolt right in the H, using early 460 parts, (flywheel, engine plate, rails, super H clutch disk, with 460 clutch, H throwout bearing, and H pilot bearing. Shold be the same items to match up on the M-560. ChadS
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
