Re: TA Question
Posted by RB on March 17, 2004 at 10:37:28 from (65.128.140.185):
In Reply to: TA Question posted by bones on March 17, 2004 at 07:13:54:
Remove the plug at the botton of the MCV (mutiple control valve) its o-ring thread, install gauge of 300lb. or more. Should read at around 225lbs. Note; pressure at engine idle, at 1200rpm. with TA forward and back. Also turn steering wheel back and forth and note gauge reading. Normal TA scenarios; leakage inside TA, weak pump (won't show on pressure test) external linkage binding or damaged or misadjusted. Good luck!
Post a Followup
: Re: Re: TA Question
