Re: More Sickle Mowers
Posted by Dave H (MI) on April 01, 2009 at 14:46:25 from (205.188.116.73):
In Reply to: Re: More Sickle Mowers posted by LMack on April 01, 2009 at 14:17:18:
ACTUALLY...there was a C-24 McCormick mower made for the C. There were also mowers made for other letter series tractors which are not in your list above. In addition there is the 25 and 25V which were similar to the JD #5 mower. As to your other numbers...100 is a trailer and probably 105 too, 110 and 115 (not listed) are mid mount. 120 is a semi mounted mower. The 1100 and up mowers were NOT all pull behinds. 1110, for example, was a mid-mount mower. Cannot speak to your 200 series mowers but the 100 series and 1000 series would be balanced head mowers without pitmans.
