Re: Farmall B Valve train stuck in head
Posted by gene b on March 18, 2004 at 04:26:14 from (67.1.104.47):
In Reply to: Farmall B Valve train stuck in head posted by Bill on March 17, 2004 at 17:03:13:
The two sstuds holding the rocker assy mite be stuck because the rocker shaft has a flat spot for the stude to clear and if they were not lined up and they used the nuts to press it down in position it will be hard to remove. You will have to bee carefull or you can break the rocker shaft quite easy. You mite be able to unscrew the studs first. You can tell if this is the problem as the threads will be marked from the assy being forced on. Good luck let us know if you get the assy off. gene b
Post a Followup
: Re: Re: Farmall B Valve train stuck in head
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
