Farmall Tractors Discussion Board
Re: Re: Farmall 12 Volt Conversion Diagram
Posted by Bob M......yes on October 20, 1999 at 06:39:12 from (192.232.120.194):
In Reply to: Re: Farmall 12 Volt Conversion Diagram posted by Ludwig on October 20, 1999 at 06:06:16:
Ludwig - Diagram is for the Delco type 10SI or 15SI internally-regulated alternator. These were used on nearly every GM car from the mid-70's thru the mid-80's
- readily available and inexpensive!
Post a Followup
: Re: Re: Re: Farmall 12 Volt Conversion Diagram
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
