Re: Rough running M farmall Day 2
Posted by riverbend on March 18, 2004 at 19:12:14 from (208.160.33.21):
In Reply to: Rough running M farmall Day 2 posted by dave w on March 18, 2004 at 18:26:46:
Try hooking up an inductive timing light to your #2 spark plug wire and see that the flashes look uniform. That would rule out an ignition problem (as long as you have a good plug). The carb should affect all cylinders equally. If you have 100 psi, both valves are closing. Did you check to see that both valves on #2 were opening when you had the valve cover off ?
Post a Followup
: Re: Re: Rough running M farmall Day 2
