Re: Rough running M farmall Day 2
Posted by 49 Cubber! on March 19, 2004 at 13:41:13 from (206.74.216.189):
In Reply to: Rough running M farmall Day 2 posted by dave w on March 18, 2004 at 18:26:46:
Had excat same problem on my H,did all the same things you did.Manifold gasket!If you got a little propane torch or some WD40 spray it around the manifold where it bolts to the head.of course if you use propane,dont lite the torch.Of course mine was a combitnation of WAY or of adjustment rockers and the gasket.Your problme could also be a bent rod,but I dought that.
Post a Followup
: Re: Re: Rough running M farmall Day 2
