Re: Re: help with M radiator/steering shaft!!
Posted by CNKS on March 19, 2004 at 13:53:52 from (207.178.96.211):
In Reply to: Re: help with M radiator/steering shaft!! posted by rick on March 19, 2004 at 13:21:56:
The shaft comes out the front, I think it turns to the left as you face it, anyway whichever way it unscrews. The seal I was referring is in the rear hole that the shaft goes thru. The upper bolster is the whole upside down V shape casting that the lower bolster (with the wheels) bolts to at the bottom, and that the steering shaft goes thru at the top -- in other words the thing you are talking about. You can't the shaft out the back because the worm gear on the end of the shaft won't fit thru the hole in the rear of the bolster.
Post a Followup
: Re: Re: Re: help with M radiator/steering shaft!!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
