Re: help with M radiator/steering shaft!!
Posted by bugsy on March 19, 2004 at 19:10:18 from (209.153.7.64):
In Reply to: help with M radiator/steering shaft!! posted by rick in Sioux Falls SD on March 19, 2004 at 12:29:32:
Rick, You did a few things that you didn't need to. Once you removed the plug on the pedestal you didn't need to remove the cotter pin and bearing. They turn out with the worm gear, no need to take them off. If you disconnect the steering shaft at the center of the tractor you should be able to screw the shaft out the front of the pedestal. Good luck.
Post a Followup
: Re: Re: help with M radiator/steering shaft!!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
