Re: Re: Gas tank valve
Posted by Brian on March 20, 2004 at 12:12:53 from (63.163.137.152):
In Reply to: Re: Gas tank valve posted by Dave in CT on March 20, 2004 at 07:32:07:
Mine doesn't have a sediment bowl just a valve in the bottom of the tank, then a line to the carb. Not sure what you would call this valve. Screws in to the bottom of the tank. The line hooks to the side. The valve turns up into the bottom like a needle valve. Around the packing nut is where it leaks.
Brian
Post a Followup
: Re: Re: Re: Gas tank valve
