Re: Operating tractor w/ cracked exhust manifold
Posted by Bob M on March 20, 2004 at 18:19:21 from (66.67.10.249):
In Reply to: Operating tractor w/ cracked exhust manifold posted by Pete on March 20, 2004 at 17:34:43:
Aside from the obvious heat hazard to nearby wiring, sheet metal and the like, running with a cracked manifold will cause no harm.
I've had good luck temporarily patching a cracked exhaust manifold by covering the crack with fiberglass or Nomex fabric, then securing the fabric with a worm gear hose clamp. Not pretty, but it will keep the fire where it belongs inside the manifold until it can be replaced.
Post a Followup
: Re: Re: Operating tractor w/ cracked exhust manifold
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
