Re: Re: 80-90w in the distributor?
Posted by Hugh MacKay on March 22, 2004 at 02:40:57 from (216.208.58.126):
In Reply to: Re: 80-90w in the distributor? posted by rebuilder on March 21, 2004 at 18:34:16:
rebuilder: The IH techician that got me started on the white grease was suggesting this grease was much better in cold weather for those tiny gears.
He said he had seen evidence of some damage created by heavier greases, especially is cases where tractors were used only ocasionally in cold weather and condensation was a factor. I personally have never bothered with zerks. I buy the white grease in squeeze tubes, just remove the plug and apply with the tube. I only do it once per year also.
Post a Followup
: Re: Re: Re: 80-90w in the distributor?
