Re: Re: Re: Re: Zenith Carb, update!
Posted by Slowpoke on March 23, 2004 at 21:09:29 from (67.30.100.79):
In Reply to: Re: Re: Re: Zenith Carb, update! posted by Tommy H on March 23, 2004 at 14:36:29:
Zenith 161X7-9749 (IH 48 616 DC) is for A-AV-B-BN kero. or dist. according to the I&T manual. Not listed for any Super A version.
Super C gas is a Zenith 67X7-????
If someone has a Super C parts book we may be able to identify the correct factory zenith carb. for your tractor. And I can add the info to my I&T manual.
But if the carb you have will bolt to the manifold, and the throttle, choke and fuel line match up, put it on and run the tractor. Nothing is going to be damaged or blow up. If it runs OK, then it just won't be as efficient as the correct factory carb. At least you can use the tractor while finding the right part.
Post a Followup
: Re: Re: Re: Re: Re: Zenith Carb, update!
