Re: 574 water pump
Posted by DavidK in KY on March 24, 2004 at 04:30:11 from (207.69.140.32):
In Reply to: 574 water pump posted by Matt on March 23, 2004 at 18:13:53:
Matt, you must have a gas engine. If so , I think you are leaking out of the bypass port.
There should be a rubber sealing ring that fits in the grove to let a small amount of water bypass the thermostat untill it opens. Your CaseIH dealer will have this under part #402928R1. Hope this helps.
Post a Followup
: Re: Re: 574 water pump
