Re: 350D DIESEL
Posted by Evan350 on March 24, 2004 at 13:17:05 from (129.42.208.182):
In Reply to: 350D DIESEL posted by Joe on March 24, 2004 at 12:49:44:
The 350D has an oil bath air cleaner. Unless it got bashed up so air doesn't flow through it any longer, all you have to do is take the bowl off the bottom, drain the oil out, clean it up, fill with clean motor oil to the line, and replace the bowl.
Post a Followup
: Re: Re: 350D DIESEL
