Re: Re: Re: Re: International 354 identification
Posted by Greg on March 24, 2004 at 19:19:45 from (67.31.227.102):
In Reply to: Re: Re: Re: International 354 identification posted by Milton on March 17, 2004 at 08:19:37:
Milton, I was able to go look at the tractor in question this weedend. Here's the #'s:
ID tag:
model# A480003B001256
serial# BLANK
Engine:
BD154
114673
Looks like it's a 364 since it has the diesel 154 engine - is this correct? What year model is it? I assume since you had all the info on the 354 you would know about the 364 also. Thanks. Is this tractor worth $3800? Keep in mind, a friend of mine has the tractor. I know it well - mowed hay with it about 4 years ago for 3 years in a row. It is VERY strong mechanically. We put a new lift and steering pump on it back then. It had a wiring short that melted all the wires since then so he has rewired it and repainted it. It is absolute show quality paint but it look very good. Seems that the charging system isn't working right, he thinks the short may have fried the Delco alt. he put on it years ago. The tach hasn't worked in years and the fuel gage doesn't work. What do you think?
Post a Followup
: Re: Re: Re: Re: Re: International 354 identification
