Re: Re: Do I need a gasket ??
Posted by Harry on March 24, 2004 at 19:39:05 from (4.63.74.15):
In Reply to: Re: Do I need a gasket ?? posted by Dan on March 23, 2004 at 21:44:53:
I always pack a new pump with vasoline..... It allows it to immediately pull oil up into the pump and is thin enough to disolve in the oil once warm.
As far as the gasket goes, get some of the permatex "form a gasket" and put a bead on the mating surface. You don't want a leak if the mating surfaces are not perfectly flat.
Post a Followup
: Re: Re: Re: Do I need a gasket ??
