Re: H bolster pivot shaft thrust bearing
Posted by randy hall on March 24, 2004 at 21:47:15 from (209.11.236.21):
In Reply to: H bolster pivot shaft thrust bearing posted by mike in PA on March 24, 2004 at 19:13:02:
i just finished fixing up an 'h' and the spacer you mentioned was really worn down so i made a new one.
Post a Followup
: Re: Re: H bolster pivot shaft thrust bearing
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
