Re: W6 leaking gas
Posted by rustyfarmall on March 26, 2004 at 04:49:38 from (207.32.13.232):
In Reply to: W6 leaking gas posted by Jonny on March 25, 2004 at 21:24:29:
You will need to rebuild the carb to cure the leaking gas situation, and the backfiring is most likely caused by sticking valves. Remove the valve cover and take a look. You may need to spray some penetrating oil around the valve stems and tap lightly with a small hammer to get them freed up. You will most likely need to remove the rocker assembly to do this, and then properly set the valve clearance when you put it back together.
Post a Followup
: Re: Re: W6 leaking gas
