Farmall Tractors Discussion Board
Super A Snowplow
Posted by Stan on October 21, 1999 at 06:31:03 from (12.67.148.118):
I have an snowplow that uses an A frame underneath the tractor that connects where the draw bar would bolt on as a hard point mount. As I understand it this is different than the blade made for the tractor. Raising and lowering the blade is done using only the drivers side hydraulic arm and a cable attached to very near the front on the blade. Hard point for the lift is forward of the position where the cultivators bolt on.
My question is:
Since the plow weighs at least a 150+ pounds do you think that will be too much for the one lift arm?
Post a Followup
: Re: Super A Snowplow
