Re: 3 POINT CONVERSION
Posted by Terry Brooks on March 26, 2004 at 12:26:42 from (169.200.173.34):
In Reply to: 3 POINT CONVERSION posted by KELLEY on March 10, 2003 at 18:59:57:
I have a 3-point hitch on my Super-C as I do not have a two point hitch. It works good for me, I have the front cultivators and a three point hitch layoff bar with three sweeps on the rear. I cultivate my garden with it using one side of the cultivators one row style. I also use a Woods 5 ft.grooming mower on the back, a nine shank tillage tool, and a rear scrape blade. The only complaint that I have is it doesn't pick up my three point hitch disk harrow quite high enough to get the rear disc off the ground. My three point bushog is the same problem. I am thinking I can overcome this with lenghtening my lift arms maybe six inches and adding a shorter top link. The best bet is too add a hydraulic cylinder to the rear to push up the 3-point higher like a 2-point. I might do that some time. For right now I have two tractors the other being a Ford 2000 High Crop and I can take care of the discing etc with that one. But I love that Super-C. It is a cultiviating and mowing machine. I forgot to mention that my 3-point hitch works off of the rockershaft. Good Luck.
Post a Followup
: Re: Re: 3 POINT CONVERSION
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
