Posted by F-Dean on April 01, 2009 at 15:54:46 from (67.72.98.87):
In Reply to: 12 volt conversion posted by Wayne S. on April 01, 2009 at 08:51:48:
Most likely, the alternator is a three (3) wire set up which can be converted to one (1) wire. There are spade connections labeled S & L and a BAT post connection. The L spade is for the idiot light and can be disregarded. Use a jumper wire from the S spade to the BAT post and you are good to go.
Run a wire from the BAT Terminal to the positive cable on the Starter switch.
Be sure to switch the polarity of the battery to Negative ground to avoid damaging the Alternator. Consequently, you need to switch the wires on the coil, if you are using a coil. You can eliminate the balast by using a 12-volt coil.
Use a plastic covered connection when you connect the jumper wire from the S spade
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
