Re: Why does a tractor lope in roadgear?
Posted by john d on March 27, 2004 at 19:31:28 from (152.163.252.227):
In Reply to: Why does a tractor lope in roadgear? posted by Wayne in Iowa on March 26, 2004 at 19:25:37:
I don't think I'd take anymore road gear trips until I found out why! Jack up one rear wheel at a time, (KEEPING THE BRAKE FOR THE OTHER WHEEL LOCKED!) put it in neutral, and rotate the wheel. See if it wobbles, or if it runs out-of-round. If it doesn't run true, set something next to it to use as a guide, and try to determine if the problem is in the axle, the wheel, or the tire. It could be as simple as something bent, something installed incorrectly, or a defective tire.
If I let my SM set for a week or so without running, the rear tires on it tend to "flat-spot." Working it a few minutes fixes it.
Post a Followup
: Re: Re: Why does a tractor lope in roadgear?
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
