wiring a starter
Posted by farmallsc on March 28, 2004 at 13:06:19 from (205.188.209.42):
when i go to wire my starter up i need to (negative ground)
1.short black cable to the body of the tractor from negative terminal
2. positive wire from positive terminal to starter
3? im pretty sure its positive, but to where?
Post a Followup
: Re: wiring a starter
