Re: Dual Hydraulic Remotes?
Posted by Smith1000 on April 01, 2009 at 16:10:53 from (12.213.112.56):
In Reply to: Dual Hydraulic Remotes? posted by Smith1000 on March 31, 2009 at 16:58:00:
Thanks for all of the great recommendations.I will definitely pursue one of these options. The valve that I currently use is operated by a long rod to the right of the steering wheel. There are 2 rods, an upper and a lower. I must allow the 3 point hitch to ride up to its stopping point and then the upper rod is used to open and close the baler gate.
Works the same when I run the log splitter. I might have 2 extra ports I can tap into to run directly to a spool. I'll look at that. That might be a better option. I have a front-loader on it. The bucket is a trip lever. The lift is tied into the 3 point hitch lift. There is a valve. Sounds like the baler would work with it.
