Re: H Delco Distributor part numbers?
Posted by Larry in CO on March 29, 2004 at 18:57:54 from (32.97.110.142):
In Reply to: H Delco Distributor part numbers? posted by phillip on March 29, 2004 at 17:33:01:
Phillip,
Here are the numbers you need for all the parts - at least that's what my '46 H with a Delco distributor needed.
The distributor cap is NAPA part number RR145.
The rotor is NAPA part number RR83.
The points set is NAPA part number CS763A.
The condensor is NAPA part number RR174.
Hopt this helps,
Larry
Post a Followup
: Re: Re: H Delco Distributor part numbers?
