Re: Check Location on M Belly Pump
Posted by Andy Martin on March 30, 2004 at 18:39:59 from (67.248.244.192):
In Reply to: Check Location on M Belly Pump posted by GB on March 30, 2004 at 18:14:42:
Drain plug is down at the bottom.
You check the level by pulling the dipstick out of the fill opening at the top. The dipstick has a flat washer at the top under the fill cap. You may not have one, lots are missing. If you start pumping air, add two quarts.
I think they hold six quarts.
Post a Followup
: Re: Re: Check Location on M Belly Pump
