Re: Farmall H series
Posted by Randy in NE on March 31, 2004 at 03:58:17 from (216.58.237.20):
In Reply to: Farmall H series posted by Jeff on March 31, 2004 at 02:46:55:
When you replaced the battery cables did you make a good ground connection where the ground cable fastens to the frame? Also, have you taken the cables loose from the push button starter? If any/all of these are not making good connection you will not get a good circuit. You can also jumper across the push button to rule that out.
Post a Followup
: Re: Re: Farmall H series
