Re: Re: 1949 Farmall M hydraulic questions
Posted by NDS on March 31, 2004 at 05:06:54 from (64.12.117.22):
In Reply to: Re: 1949 Farmall M hydraulic questions posted by moonlite on March 31, 2004 at 03:39:00:
Everyone has different opinions but I have found the Saginaw works very well on M. Have used one for over 25 years with cultivator, planter, rotary cutter, boom pole, scraper blade etc. with good results. About only thing I would not reccomend it for is moldboard plow. At time I put most of time on M there were several late model 3 point tractors on place so I had something to compare it to. Have special IH cylinders on lift that have adjustable hydraulic stops by slidindg collors on cylinder shafts can stop down travel of lift anywhere you like.
Post a Followup
: Re: Re: Re: 1949 Farmall M hydraulic questions
