Re: Re: Re: Re: Re: Hey, I've got a Farmall C, cou
Posted by Stan(VA). on March 31, 2004 at 11:48:38 from (69.19.0.1):
In Reply to: Re: Re: Re: Re: Hey, I've got a Farmall C, couple posted by Bill M on March 31, 2004 at 09:52:38:
Make sure the comparison is equal. The cheaper kit may be just pistons/sleeves/gaskets/bearings, while the other kit may also include the valve train set (valves/guides/springs/keepers/seals). Not saying it's a good deal, just compare apples to apples.
General Notes:
The comment on reconditioning the rods is good, so make sure you get the pin bushings with your OH set. Pull a sleeve and measure the bottom OD at the O-ring seal to make sure which sleeve set you need (3 5/16" for the original C motor, possible 3 7/16" on a replacement block from a Super C). Mill the bottom plate on the oil pump flat. Make sure you keep all the main and rod bearing caps in the right place, they don't interchange.
Stan(VA).
Post a Followup
: Re: Re: Re: Re: Re: Re: Hey, I've got a Farmall C, cou
