Re: Re: 1949 Farmall M hydraulic questions
Posted by NDS on April 01, 2004 at 05:28:42 from (152.163.252.227):
In Reply to: Re: 1949 Farmall M hydraulic questions posted by jamie ivester on March 31, 2004 at 19:36:05:
That sounds like standard belly pump. Should be one outlet on right side also. I run my Saginaw directly off one of these outlets. To do initial check simply pull back lever that goes to arm in this area on right side. With tractor running at idle in neutral clutch out you should hear motor load up if pump is working. Might be good idea to remove 1/2 inch plug in casting that drops down under tractor in this area drain oil and add 6 qts. non detergent 30 W oil through 1 inch pipe that sticks up through top.
Post a Followup
: Re: Re: Re: 1949 Farmall M hydraulic questions
